Reduced my Wingy-Thingy count by two Thursday at Flite Fest 2024.
What remained of my 3 RMRC Nano Skyhunters made it through morning combat on thursday with battery giving up the ghost just before the final pushes for destruction. I had a battery in it charged for the final combat last year but didn't get to fly it then. Had 94% charge after a year of sitting charged for nearly a year. LOL Lasted surprisingly long with no sag and still has good resistance. Picked it up out of the field with a trophy embedded in the wing.
Franken Skyhunter only lasted about one minute into the second Thursday combat and I FINALLY experienced the dreaded DSMX failsafe of doom causing probably the first lawn darting of that session. No reglueing. Every piece had been severely stressed and repaired many times before, and the intent was just to finish it off in combat. Only wish it would have been air-air rather than air to ground.
My Original Nano Goblin (from 2017) Lawn darted at an even higher impact rate but for a completely different reason..... Dead glue. Was still flying INAV, BrainFPV, R9, but LOS rather than FPV. Had been ripping it around a lot, put it in a high speed dive from high up, went to pull out...... Nothing. D'OH! The glue on the elevon control horns had let loose letting the control horns pivot around the elevon spars rather than actuating them. This was an original initial release PNP built at the factory model with an unknowwn glue which had hardened, turned yellow, and become brittle. Not the first time I have had glue come apart on this bird over the many years, countless hours in the air, and probably 1000-ish miles. The nose had been completely ripped off and reconstructed in it's INAV maiden. I used Foam-tac for that reconstruction which held up remarkably well in this impact. Many pieces that had not been re-glued over the years of abuse popped. It plausibly could have been repaired and used for combat, but the decision was made to let it rest in pieces and make room for a new flyer in the hanger. Rescued 1 servo, ESC, Motor, Prop and all electronics except for the camera that found a rock at impact obliterating the lens.
Still have Nano Goblin #2 which I built as a kit with Foam-Tac after #1's nose exploded off in the INAV maidening many years ago. #2 is still ripping strong. Still have plans to replace the Aura5/FrSky D16 with an ArduPilot FC/ELRS setup. FPV upgrade from dead AIO TBD....
