Its crappy when you find out, no shop close have any more foamboard in storage, and fastest delivery online couldnt deliver before end of month, start of next month...
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Lucky enough, i had nearly enough to the topskin of the last wing. Fine tuning of some scrapfoam from the "garbage box" in connected edges, and some extra finishwork, the last part , right wing is also ready! A bit more work to shape the foam because the gluejoint dont bend similar as a plain foamboard with no cuts. Careful use of a heatgun did the trick.
Then next "sh**" showed up, a couple of the planned used 9g servos was suddenly crap, and not any other in my storage.
![Cautious :cautious: :cautious:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Well, at least extra ones be delivered me in a few days.
Even if they was from a wrecked plane with no damage around the servos/cables, and worked then... they now got troubles. Cheap 9g servos cant be trusted..even if worked before....lucky did a check before glued in...
