leaded50
i had a plan......or?
Ive started getting the resources i can find about my next possible build. That plane ive never found mentioned made as an "full" RC model.... just as a single 3D version. And fit my style with unusual builds good, since just got to be a "paperplane", not getting further to even a prototype. US didnt had a belive on jetplanes that time. Lockheed made the planned jet engines... it was very powerful.
the Lockheed L-133 Starjet fighter!
Its a heritage, US first planned jet fighter!
-not a easy build with its shaped curves and blended parts, and very little things to use, but found a 3D drawing, that could be used, together with some pictures by 3D games eg, tht help understand the design. but i believe it should go. If not, ive tried
. 2 x 64mm EDF is in order!
Its a really canard type plane, and never made, just as an US fighter design proposal in early 40´s . Its wing plans was in fact used by the P80.
in 1/10 scale its approx 1400mm long & wide..after checking by the drawings i have, it need be approx 1300mm long to use the EDFs without disorting fuselage shape, at a place where it easy will show. I suppose some adjustments on the airintakes are needed though so the EDF can breathe.
This plane will also be build as a best possible true copy, using masterstyle, and by size, i feel needs detachable wings for better space in transporting, eg.
