Years ago I got a hold of a Turnigy 9x, which is a complicated story in itself, one which probably wouldn't have ended in that particular radio if things had gone differently but alas!
So, I just had a birthday (29, not looking forward to next year :| ) and figured I could use the birthday present as a method of getting me in the hobby and so I ordered my FT Gremlin (which is now completed minus the RX).
The thinking at the time was to either go a micro receiver for the 9x or just use the included 8channel huge RX and just have it hilariously sitting on top but due to less than stellar research on my part, I now seem to have found that there are no micro sized / ppm receivers that will work the the stock 9x, and that the larger 8channel RX doesn't output PPM.
SOOOO,
Next mission is to swap a new module into the 9x but I'm stuck for which way to go. I like the idea of the DIY FrSky modules and just hooking it up inside the case but there appears to be multiple versions of that too, with or without telemetry etc, and then comes the question of which RX specifically to use.
In an ideal world I'd go out and buy myself a better new radio but A] I keep myself to a really strict budget and can't really justify it with an 8 month old crawling around and only one wage and B] I started this process attempting to use what I already have and kinda wanna see it through.
TL;DR
In order to make use of my existing radio, and have access to affordable, compatible receivers for potentially more multi-rotos / fixed wings now and into the future, what should I get?
SOOOO,
TL;DR
