So I've been lurking on the awesome needle cutter thread long enough, and want to try my hand at CNC routing / needling of both foam and wood. The popular option for the machine is of course the MPCNC - but that takes up a lot of room that is dedicated single use space just for the machine. And I have a very small work shop.
So I'm going to tackle the Lowrider CNC by the same guy who designed the MPCNC.
The big advantage of this design for my workshop is when I'm not actively cutting something, I can push the carriage off to one side and use the open space as a work bench. I'm still working out the final dimensions, but I'm not looking to have a useable space much larger than a sheet of dollar tree foam. Right now the rough overall machine dimensions are looking like 36" x 50", and if I build the table top it rides on up at a comfortable standing workbench height, I'll have plenty of room for storage underneath.
I'm saving some money on this project by reusing components from my first 3D printer like the stepper motors, RAMPS board, limit switches, etc., I even have a pile of bearings on hand - accidental order of 10 sets of 10 instead of just 10 bearings a while back. But the first step was to see if it's feasible for me to make this with the equipment I have on hand. So I tried to print out some of the parts on my trusty Folgertech 2020 i3 printer.
Here's the parts for the primary carriage - and what do you know, the bolts and bearings all fit! :applause:
After printing the carriage template on paper and taking a sheet of 1/4" mdf to the band saw I was able to get the first assembly put together tonight.
So I dropped an order with http://www.vicious1.com/lowrider-cnc/ for the wheels, lead screws, and other miscellaneous parts I'm missing and started trying to figure out where I'm going to get the stainless steel tubing from. There is one supplier I see locally, but by local I mean an hour away on the other side of the city.
And when I mentioned this project in the earlier mentioned awesome needle cutter thread, jhitesma turned around a modified needle cutter design in an afternoon! So yeah, this needs to happen.
Anyway, other than getting the tubing, and some lumber for the table, I think I have everything I need to build it - except the space to build it in of course. Really need to get to work cleaning and rearranging the shop...
