Lumenier Lux V2 Problems
Hello! I'm here and I just upgraded my flight controller to the Lumenier Lux V2 from the Naze 32. I'm Flying a FT210 with Emax 2205 2300kv motors with lumenier 30amp BL-Heli ESC along with the Lux V2 and a Turnigy 9x radio and Rx with a ppm Encoder.
My quad was flying just fine before I upgraded and now that I upgraded, my drone Is unflyable. I take off and my throttle is very lagged out, its more noticeable with bigger throttle changes. If I punch up and then back down my throttle, my drone continues to fly up for another 1-2 seconds then drops down to where my throttle is and falls out of the sky everytime. I had no issue before, the only thing I changed was the flight controller and now I have this issue. In Beta flight under the receivers tab, while moving my throttle around, it corresponds instantly with my stick movement but does not translate when I go to fly. I'm stuck and have no clue what to do. I'm new to the hobbie and this is my first build. Any help would be greatly appreciated!
#2
Have you checked to see if there are any faulty joints with soldering that could cause any latency from your receiver to your flight controller, or flight controller to motors? I would imagine the issue is not due to the lux v2 itself but the connections made with other pieces of hardware.
