This is my last Hotprops practice session. Still trying to find the fastest set up to fly in the sim. This one is my fastest so far.
physics settings are:
100 mm arm length
200 mm body length
50 mm body width at 535 gr
5s battery spinning 5x5x3 inch props.
RC rate is 2,2,2.05
Super rate is .63,.63,.65
Max vel is 1081, 1081, 1586
and zero expo across the board.
This is 60 degrees FOV with 53 degree tilt on the quad.
I played with the motor kv slider until I found the highest thrust I could find which for this run was 1815 gr. Flat out run across the field above the obstacles got 172kph top speed. Originally I have been flying with the settings more close to the actual ones of my Alien in real life. I been doing a lot of sim flying with the bad weather so I figured its time to up the game and get some of the old reflexes back from my younger "I wanna race everything" days of speed.
If anyone else uses this and has a faster settings feel free to post it here so other can try.
100 mm arm length
200 mm body length
RC rate is 2,2,2.05
