Northrop P-61 Build-Log designed by the 13th Squadron
FoamyDM
Building Fool-Flying Noob
The ARCN build party was a productive time this afternoon. I worked on the canopies. Here is the rear section:
IMG_20211219_002150483.jpg IMG_20211218_135343976.jpg IMG_20211218_135339995.jpg IMG_20211219_002139278.jpg
Here is the removable front canopy.;
IMG_20211219_002133930.jpg IMG_20211219_002128742.jpg IMG_20211219_002114775.jpg
Next step is lights, camera(s), action!
Niez13
CrshNBrn
I just painted the cowling on #2 last night. The decals are homemade and leftovers from other projects. Maybe there's a little outward angle, but they looks pretty straight to me. Have fun flying yours.
FlyingTyger
It's not necessarily a bad thing, probably not as important on an electric twin because the risk of an engine out is much lower. Looking back at the pictures, I now see that the motors are not screwed in place. That would explain why they looked so angled.
FoamyDM
I went back and straightened out the base plates with a ruler between them and I tighten up the screw instead of the motors are facing the exact same direction. Then I started getting to work the wheels and the landing gear which I'm going to leave as fixed. During the last night's arcn build night, I got them installed and made sure that the front lineman gear Head support while still leaving enough room for battery up in the nose. After getting pretty much everything on including a prop I went to go back and balance the plane and realized that the battery really needs to be placed essentially under the wing. So I carved a hollow in the belly underneath the wing and it looks like things are ready to go.
IMG_20220326_004225574.jpg IMG_20220326_004237885.jpg IMG_20220326_004248566.jpg IMG_20220326_004317738.jpg IMG_20220326_004429086.jpg IMG_20220326_004433653.jpg IMG_20220326_004452144.jpg
FoamyDM
Hit a small Snag. my one transmitter has the Throttle backward. turned on, the motors dutifully fired up. and hit the chair it was resting on. after fix the error, I fired it up again, and it one motor mis-fired (esc connection damage?) and stuttered. I had lost patience to trouble-shoot this.
I will get at this soon. I will also be setting this up with my T16 instead.
Niez13
Maiden Flight:
She Flies, and will again. I may need to move the battery forward a hair, and trim.
That's a bummer Matt, but don't give up on it! I promise it will fly. Do you think it was just from the hatch coming off or being a little tail heavy?
FoamyDM
I could see by the first moments, it was ready to fly, thanks for the encouragement. When the canopy came up, not off right away, it really changed the flight characteristics. I will tape it down next time.
