Resource icon
Mighty Mini Sea Duck 1.2
Please log in to download
Jo's squadron
So I finished my second mini sea duck and I flew it twice, but it keeps stalling!
Like I will do a dive pull up to recover and it just stalls and goes into a spin (my first one did not do that), so what is happening?
Here is a list of what I think I should try (if you guys have any other ideas pleas let me know)
- fly it nose heavy
- fly it tail heavy
- try to stall it without throttle
- cut some of the under side of the wing to ad undercamber
BTW that was on a 1500 mah 3s battery, and the all up weight was 450g (I think).
@Mr NCT, @L Edge, @Mr Man, @Horseman3381
L Edge
- fly it nose heavy
- fly it tail heavy
Why don't you make yourself a camera hat so you can video what is happening. That will help us analyze what the problem may be. To me, diving and if you pull up too sharply(what direction was the wind), you can very easily go into a stall and start spinning. Sea duck is not a fighter, you don't yank and bank it. If you have rudder?, might counteract it and save it spinning. If you plan to do acrobatics, better learn how to use the rudder. Once you learn how to fly inverted, can fly a knife edge, you can learn to do anything. Heck, if you get enough experience, you could even hover the Sea duck.
Just guessing, you probably pulled too sharply up and you saw the consequences.
Horseman3381
- fly it nose heavy
- fly it tail heavy
I would try moving the Battery forward as you and others have mentioned to get the CG further forward. The CG should be under, or slightly in front of the crease in the front top part of the wing.
I had a similar issue happen with the 2nd mini I built and the CG ended up being half way between that crease and the front of the wing.
I have had issues on various planes where the CG has seemed to change when I have rebuilt planes before, and it has often been because I folded the wing slightly differently/not quite correctly (this was my problem on the mini sea duck I was having issues with), the motor pods are angled with the motors pointed up slightly, or in the case of the many Sea ducks' I have built, the booms didn't get aligned quite correctly. With a plane this size, it doesn't take much to get things misaligned and add some "character" to the planes flying experience.
I once built an FT Mustang, and the CG ended up being about 3/4in farther forward!
Jo's squadron
Thanks that helps!
Jo's squadron
Thanks all for the replies!
When I tested it with the CG farther forward it seems to be better, but I stripped an aileron servo doing that.
So I need to replace it before I try again.
