Mini foam Spitfire project
DazDaMan
So I dug out this old project the other day - it's made from 5mm foam sheet, with 3ch (E/A/T) control, and was to be powered by a smaller motor I had lying around. The wing was originally a KFM-2.
I was toying with make it from the 5mm West Foam board and using a flat-plate wing section instead. For power, I was thinking of using the setup for the Flite Test Mighty Mini Scout (https://www.flitetest.com/articles/ft-mini-scout-build-mighty-minis)
Thoughts?
Crstn_Jdi
Thoughts?
That's what I was thinking about, something like this exactly to make and try it out with the MS might mini spitfire and see if it makes the airframe less likely to stall as bad . Do you have the plans to this ? If not, I'll keep on looking. ^_^
