Covering complete!! There are a couple little wrinkles here and there that I want to try and take out still, but I'm planning to fly this bird not take her to Top Gun.
So the thing I learned on this build is if you are using different brands of covering, read the darn instructions before you start applying them. The brown stuff is a brand called Oracover that I got from a swap meet, and the cream color is Econocote from Tower.
Using good color management, I laid down the lighter color first of course. Then when I started with the brown I noticed it wasn't sticking well. Looked at the instructions and found the Oracover application temperatures are about 50 degrees higher than the Econocote!
If I had found this before I started covering, I would have grabbed a different color - cause putting trim pieces on that need a higher temperature than the stuff underneath it is pretty tricky. In a couple places I messed up and had to strip part of the cream away that I shrunk up too much.
But I'm pretty happy with how she looks! Now it's time for stuffing in the electronics and epoxy for the tail pieces!
