mrjdstewart
I am trying to set up a F-22 with twin motors that have thrust differential and tailerons.
i have a Dx8 Gen2 and am using a 6 channel Rx. i have wing type set as normal and tail set as taileron.
i have the thrust diff nailed no problem but it is using the Aux1 channel. Having never used a taileron setup before i quickly learned that you need a channel for both elevators. my first thought was to move the 2nd motor to channel 5 (gear) and change that channel in the channel assign, then mix as usual for thrust. i then would have the Aux1 channel for the tailerons. this did not work. not only did 1 elevator not work, one motor quit working.
my original mix for thrust diff was;
mix 1- Throttle>Aux1 100% 100%
mix 2- Rudder>Throttle -100% -100%
mix 3- Rudder>Aux1 100% 100%
this worked perfect for motors but not for tailerons.
i switched that to;
mix 1- Throttle>Gear 100% 100%
mix 3- Rudder>Gear 100% 100%
and assigned gear channel to throttle, and now i only have 1 elevator and 1 motor
i have a 9 channel Rx but would prefer to use the 6 if possible, what do i need to do?
if you can help with the 6 channel awesome, if i have to move to 9 channel fine, just let me know what to do.
thanks,
me
i switched that to;
thanks,
me
