Date time=[2013/07/28-14:15:13];date time setting,format yyyy/mm/dd hh:mm:ss
Video Mode 1 resolution=[1];Movie resolution setting,0:1080p(Large AOV),1:1080p(Small AOV),2:720p(Large AOV),3:720p(Small AOV)
Video Mode 1 Frame Rate=[2];Movie frame rate setting,1:60fps (only for 720p small AOV), 2:30fps
Video Mode 2 resolution=[3];Movie resolution setting,0:1080p(Large AOV),1:1080p(Small AOV),2:720p(Large AOV),3:720p(Small AOV)
Video Mode 2 Frame Rate=[1];Movie frame rate setting,1:60fps (only for 720p small AOV), 2:30fps
Photo Mode Capture Size=[1];set photo size,0:2304x1536,1:1920x1080,2:1280x720
Set Time Lapse Shooting=[0],0
ff,1:0.25s,2:0.5s,3:1s,4:2s,5:5s,6:10s,7:30s,8:60s
Photo Flip=[0];set Photo rotate,0
ff,1:flip on
Movie cycle time=[4];movie cycle time,0:3 minutes,1:5 minutes,2:10 minutes,3:15 minutes,4:max to 4G byte,
Movie Loop Recording=[0];set loop recording on or off,0
ff,1
n,
Time stamp=[0];set date/time stamp on or off,0
ff,1
n,
Movie sound=[1];set movie sound,0:mute,1
n,
Movie Flip=[0];set movie rotate,0:both off,1:mode 1 on and mode 2 off,2:mode 1 off and mode 2 on,3:both on,
Movie quality=[1];set movie quality,set movie data rate,0:Super,1:Standard,2:Low,
Movie high dynamic range=[1];set movie high dynamic range,0
ff,1
n,2:Enhanced Brightness.
Power on=[1];set system power on time,0:delay,1:fast
Power off=[1];set system auto power off time when system pending,0
ff,1:30 seconds,2:1 minutes,3:2 minutes,
Auto Record with External Power=[0];set connect with power to start video recording automatically,0
ff,1
n,
One Power Button to Auto Record=[0];set press power key to start video recording automatically,0
ff,1
n,
Auto Off with External Power disconnected=[0],0:Immediately,1:delay 10s;2:record to low battery power off,
LED=[1];set LED flicker when recording,0
ff,1
n,
Charge from USB Host=[0]; when connecting with USB host, charge camera or not,0
n,1
ff
Lens option =[0];select lens,0:lens A,1:lens B
Light frequency =[1];set light source frequency,0:50 HZ,1:60 HZ
TV out=[0];set Tv out,0:NTSC,1
AL,
TV Display Ratio=[0];set display ratio,0:4*3,1:16*9
Motion Detect=[0];set motion detect,0
ff,1
n
Motion Detect Timeout=[2];set motion detect timeout,0:5s,1:15s,2:30s,3:60s
Motion Detect Sensitivity=[0];set motion detect Sensitivity,0:high,1:nomal,2:low
White Balance=[0];Set White Balance,0:Auto,1:Sunny,2:Cloudy,3:Tungsten,4:Fluorescent,5:Custom WB1,6:Custom WB2,7:Custom WB3
Sunny(5000-6500K) used for sunny with clear sky(Rgain=301,Ggain=256,Bgain=368);
Cloudy(9000-10000K) used for shade or heavily overcast sky(Rgain=301,Ggain=256,Bgain=384);
Tungsten(2500-3500K) used for Tungsten bulb (or called Incandescent light)(Rgain=184,Ggain=256,Bgain=711);
Fluorescent(4000-5000K) used for fluorescent lamps(Rgain=333,Ggain=256,Bgain=525);
Customized White Balance 1 Red Gain=[256],Green Gain=[256],Blue Gain=[256];
Customized White Balance 2 Red Gain=[256],Green Gain=[256],Blue Gain=[256];
Customized White Balance 3 Red Gain=[256],Green Gain=[256],Blue Gain=[256];
Set red ,green,blue gain,256 is 1x gain,value from 100 to 999;
Color Effect=[0];Set Color Effect,0:Standard,1:Mono,2:Sepia,3:Cool,4:Cooler,5:Warm,6:Warmer,7:Vivid
Exposure Value= [0] ;Exposure compensation,values from -128 to +128,In 1 increments,default value is 0,
Contrast= [0] ;Set Contrast,values from -128 to +128,In 1 increments,default value is 0,
Saturation= [0] ;Set Image Saturation,values from -128 to +128,In 1 increments,default value is 0,
Sharpness= [0] ;Set Image Sharpness,values from -128 to +128,In 1 increments,default value is 0,
{TLCAM MOV:TLCAM Mobius ActionCam 2014/03/17 v1.20}
{LDTLCAM,v003}
