Flight report -
I've been waiting for good weather to fly, and the only decent day on the radar was yesterday. It wasn't ideal, but good enough. Winds were from the south/southeast and varied in speed from 5-10mph. The "runway" is east/west with a slight bend at the western side.
Take-off was to the east as that leads directly into a very large unmowed field, reasonably good for emergency landings, and certainly better than trees or parking lot. I don't care for crosswind take-off and landing, but it is generally manageable. Landing was aiming west because it gave me a very long straight approach to work with. If I want to land aiming east I need to fly low and slow toward the hardware store, then make a 180 degree turn and line up quickly with the runway. (See picture below) I need to be on the ground relatively quickly after that so the plane has time to stop rolling before hitting a curb. Basically, this is far from an ideal place to fly but it is a mile from my house and is very open. Take off and flight is fine, landing is tricky.
On the first flight the goal was simple - don't crash. That bobbled take-off scared me a bit and the plane was a little twitchy until I got it trimmed out. I'm not sure why it did that, possibly way out of trim, maybe not enough power or speed when I gave it some elevator...? But it got airborne. I think it could use a little more nose-weight, but future flights will tell me for sure. This flight was quick, only about 4 minutes since I didn't know what to expect for power use and I wanted to have plenty of reserve in case I needed to try multiple landing approaches. I didn't touch the retracts on this flight and kept the throttle around 3/4. It's a heavy bird and knowing I had power in reserve was nice. I did some slower flight passes to get a feel for it, to see if it would drop a wing quickly, etc and found it wasn't bad at all. I've only been flying since last year, but have around 100 hours of flight this year alone on 500+ flights so I've had harder flights. But this one was mentally taxing as I had so much time and effort into the build, and had no idea what to expect from it.
The first approach was high and gave me some info on sink rate, speed, and how much power to carry. I figured I'd need a couple more passes before I was happy with the approach, but the second approach was pretty damn good so I brought it in. The video shows it landing not far from hitting a curb, but from my angle I wasn't worried. I probably should have been, but it turned out well. I had expected a much faster landing speed due to the weight of the plane, and was pleasantly surprised how well it came in. From the picture of the field you can see that it is hard to get a good straight approach due to the bend in the road right at the cul de sac. Smaller planes are fine, but bigger planes that roll a lot have been a problem.
That first flight left me with around 70% battery left. I expected it to use more, another good surprise.
The second flight started off with a much nicer take-off. I knew the plane would fly and handle well enough to let it roll further/faster before giving it some elevator to lift off. Once airborne I cycled the gear a few times. Gear up moves the CoG back slightly so the plane did respond differently. Again, a little more nose weight will be used to see if that helps. With the reduced drag from gear up it also really moved across the sky quickly. I couldn't resist doing a few loops and rolls, both of which it did without any issue. Rolls weren't axial, no surprise there, and even without much aileron movement it responds well. They were very similar to my other low-wing planes. To this point I've only been flying it as bank & yank, so I don't know yet how much rudder authority it has.
Landing on the second flight wasn't quite as nice as the first flight, it was a two-hopper. Neither hop was big, but it did pitch up enough to drag the tail skid on one of them. I'm glad I added that piece!
Ground handling is a mixed bag. It steers well and has enough nose weight to force the plane to steer properly, but the wing gear is farther forward than ideal so if the tail were pushed down it would stay down and not drop back onto all three wheels. That's why I added the wire tail-skid. I don't know if it's visible in the video or the latest pictures, but I don't really want it too visible. It's just a safety device to keep the tail safe.
If I were to do it again (and I might) I would either go with fixed gear or with lighter weight retracts. These were big and heavy, but they worked and fit into my budget.
For transmitter programming I set up 25-30% expo on both high and low rates. Ailerons were programmed to give me maximum travel on high rates and slightly less on low. With the way I installed the servo and pushrods I wasn't expecting the ailerons to have a lot of authority, but am happy with how well they actually work. I'll reduce the throws for low-rates slightly and will leave hgh-rates at full throw. Elevator throws were a complete guess but I guessed well enough for stable flight. Rudder was left as full throw on both high and low for a couple reasons. First, I'm still not big into using the rudder, but I needed the steering ability on the ground, and full throw gives me about ideal steering. Also, there is a clearance issue between the rudder and elevator. I could get more throw out of the rudder but it would hit the elevator (the joy of adapting control line plans that didn't account for rudder movement!). I didn't notice this until the tail was assembled. Oops.
The FrSky receiver and module in my ER9X worked perfectly and took all the worry out of that part of the flight for me. It isn't an $18,000 high-end system, but it's been rock solid for me and I can't say enough good things about it (it replaced a Spektrum system that was replaced for a reason).
So as a final note on the flights, I was very happy with how it all turned out. Honestly I had started the day expecting an emergency grass landing. The heavy plane, unknown issues from the design, etc were all weighing heavy on my mind for the past few months. Plus my dad made a 6 hour round trip to watch and video the flights for me and I hate to waste his time (although he is building a contest plane as well and really wanted to be part of the maiden). I would certainly do things differently were I to build this plane again, but as it is, I'm happy.
Thanks everybody for following along with the build and providing encouragement and help along the way. I'll continue to update this build thread as warranted.
