I got to fly another half a pack through it this evening during my wife's lunch break. I'd have flown a full pack but it was dark and the neighbor kid kept getting close after I repeatedly warned him to back up. I'm glad he's curious but he doesn't take my warnings about the props very serious even after I showed him my scars from the warp attack. I think someone already convinced him that girls like scars and he's almost old enough to care what they think
Just the elevator was backwards, and I'm really not sure why. I still haven't got the widget in GCS working to see my stick inputs - and the setup wizard does goofy things when I try to setup my RX with it. On the manual setup the elevator seems correct so I'm really at a loss as to why I had to reverse that channel.
The evening flight I got to try all 3 flight modes I had setup: Leveling, Rate, and Horizon. They all felt pretty good, a little sluggish but I was on stock PID's. They all felt VERY stable, noticeably more stable than MW 2.3 feels.
From what I can tell "leveling" is basically like MW's Angle mode. Tau supports a lot of flight modes and I'm curious to try them out:
https://github.com/TauLabs/TauLabs/wiki/Flightmode-Settings
It also lets you setup custom modes where you can mix and match, so you could have Horizon on roll and leveling on pitch if you wanted to for some reason. It's a remarkably flexible system.
That antenna is for my 440mhz openLRS, but it's not in use right now and is just kind of hanging back there. I had to add a male/male barrel connector and an angle connector to get it attached to the module since I couldn't find a male male angle connector. But I worry about the stress it puts on the SMA connector on the module sticking out that far so I had to tape it to the handle on the back of my TX for support (I'd like to make a little printed plastic clamp to replace the tape, but don't have a 3D printer yet...one is in the works but not sure how long it will take.) I'm too lazy to retape it every time I switch modules so when I'm using one of my 2.4mhz modules I just leave it flopping around on there. I'm actually using the stock FlySky module that came with my 9x since my homemade FS RX is the only PPM RX I had on hand and I didn't want to deal with hooking up 8 wires.
I'm probably going to replace that antenna with a moxon one of these days...just need to order that coax and connectors I've been needing for a few weeks but things keep coming up and claiming the money I set aside just before I can order
BTW - Found out that Peabody124 the lead developer behind Tau is aware of this thread and seems excited about my experiments as well. So that was a nice little surprise tonight
Debating whether to deal with mounting the board properly tonight or working on the BMP code some more. Probably going to stick to code, don't feel like doing mechanical stuff right now and I'll feel a lot better about sealing the sensors up in the frame once they're all working.
