Dear helper,
I've just build my first rc plane, and I'm now trying to connect all the electronics together.
Unfortunatly I'm having difficulties with the motor, for some reason it does not react on throttle movement. When I switch the switch on the left side of the transmitter, the motor starts spinning for a few seconds on 8 volts.
I plugged the ESC in channel 3 of the receiver, the voltage of the battery is 11.2 volts, the transmitter is turned on before the receiver is, the throttle is al the way down when transmitter is turned on and all the servo's are working fine.
Does anyone know what I do wrong?
down below a picture of my setup, and the products I use;
ESC-->https://hobbyking.com/nl_nl/hobby-king-60a-esc-4a-sbec.html
Battery-->https://hobbyking.com/nl_nl/turnigy-2200mah-3s-25c-lipo-pack.html
Motor-->https://hobbyking.com/nl_nl/turnigy-l3010b-1300-brushless-motor-420w.html
Transmitter & receiver-->https://hobbyking.com/nl_nl/turnigy-t6a-v2-afhds-2-4ghz-6ch-transmitter-w-receiver-v2-mode-2.html
Kind regards,
JoostD
Kind regards,
JoostD
