Shadow74
Multi-rotor madman
Can't wait for your build tutorial. In the meantime, what do you think of this part list. I'm gonna order it soon. Thanks
Power distribution
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=21734
12A ESC
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=11429
Frame:
http://www.hobbyking.com/hobbyking/store/__19595__HobbyKing_Mini_Quadcopter_Frame_V1_539mm.html
Control Board
http://www.hobbyking.com/hobbyking/...ti_Rotor_Control_Board_V2_1_Atmega168PA_.html
1600kv motor
http://www.hobbyking.com/hobbyking/store/__5482__CF_28_05_Brushless_Outrunner_1600Kv.html
Running 8x4 on 2s (1000~1300mah)
Hey Nguyen! good to have you here!
As far as your parts list, it depends on whether you want to build a small/medium/or large size quad copter. For a small quad your parts list looks like it should be okay. The smaller and lighter the frame however, the less wind it can fly in, and the less payload that it will be able to carry. (if you ever wanna do FPV or carry a GoPro)
If you scratch build:
One thing I would consider changing is your ESC. If you are gonna buy everything from HK, the Turnigy Plush ESC's are known to play very well with KK controller boards and multi-rotor aircraft. Most guys who are building their own multi-rotors are using these. If they are unavailable then you can get the 20amp AX esc's from www.lazertoyz.com (thats what I have on all of my multi-rotors and they work really good.)
The other thing to do is get the lowest KV motor that you can find, I fly Park 450 motors from Horizon Hobby on my quad and they are 890kv running 10x3.8 or sometimes I run 10x4.7 props. Anything in the range of 700-900 (give or take a little) will work great. A 1600 kv motor might be a little to high of rpms which could make your quad fly unpredictable.
If you run the larger motors you will want to run a 2200mah 3 cell battery as well.
We will all help you however we can to get ya going. Talk to ya soon!
Cheers!
Eric
