Heli-Yeah!
Gremlin on the Wing
Here are just a few photos of my new swept-back V-tail. I wanted it to look fast even if it's sitting still. What do you guys think?
Some of my ideas I wanted to realize where...
Dual rear motor/prop pair should match thrust, and draw of each front rotor,
Dual rear prop pairing should be as close as possible to the same tip-to-tip span as each front props length, (rear span is 12", front props are 11" )
Fast yaw rate,
And finally, it must look menacing!
SPECS:
Flight Controller) KK2 (firmware V1.1) V-tail mix ( with reversed rudder outputs in mixer editor )
Props) 11x4.7 front, 7x3.5x3 rear
Motors) Turnigy AIR (L2215J) 900kV front, Turnigy AIR (L2210A) 1650kV rear
ESCs) HK-F20A x4 ( stock firmware )
LiPo) Nano-Tech 2200mAh 35-70C
Fast yaw rate,
SPECS:
