eagle4
There are some articles posted by CStence he called his plane the smash drone. i thought this could be a nice simple fpv plane that uses the powerpod. i'm making a few modifications along the way. firstly i'm not using the old fogey wing, i'm using my 40 inch armin wing i have from another plane i built, this has ailerons, so it should fly a bit nicer
ive also made a straight slope down the front, rather than a curve, cause im not good at cutting two curves the same lol
I plan on building a flat section at the front that'll have my fpv camera on it. but we'll see how that ends up.
as far as the plans go, they are pretty good, i found though, that the fuselage is too wide for the powerpods, i found there is about a 5mm gap between the spacers they make and the powerpod, i prefer a much more snug fit, so for the forward spacer i added two smooshed pieces of foam and it makes it a much more snug fit
because i'm using a wing that has a shorter camber than the old fogey i've had to do different mounting options for the bbq skewers than what was in the plans.
anyway, its still a work in progress, shouldn't take too long to get it up and flying
