Need some help here. Me 262 power pack sizing
Steamy Piles
Hi,
I am building that Me 262 that came out recently and I am trying to size the right battery and ESC for the best performance.
I will be using these motors Ducted Fan 70mm 12-Bl w/2845-2750kV Motor (12 blade) with a 5000 mah battery and need to know how to size the ESC.
I was thinking this Talon 90 Brushless ESC 90A/25.2V might be right... o.0
Any help here?
leaded50
if its the FMS version , its specs says as i found :
Working Voltage: 4s 14.8v
- Static Thrust: Around 1600g (16.5V , 64A)
So your plan of using the 90A is good to go! :)
telnar1236
Hi,
Any help here?
Sounds about right. Depending on the type of flying you're doing it might be a bit overkill, but better safe than sorry. Just make sure you have one per motor.
I think my FW and FMS twin 70s both use 80A ESCs.
