mikeporterinmd
Still Learning
Hope to change this to "New flyer in Maryland" soon. Just finished a Tiny Trainer. It came out pretty well, but I may redo the wing.
I didn't have the sharpest knife and I didn't realize how steep a cut I needed to make. The end result is still a pretty decent wing, but there is a lot of tape on it. Don't know how well it will fly. Also, there is more damage on one side than the other, so there could a be a left/right CG issue. Need to check that.
Quick question: in order to obtain the correct CG, I have to push my 50gram 2S 800mah battery really far in the fuselage. Nearly as far back as the hole in the bottom. Is this common? I can see no reason why the front of my plane would be terribly nose heavy. It was built exactly according to the video and uses power pack A with no substitutions. The ESC is where it should be.
Thanks,
Mike Porter
Elkton, MD
Thanks,
Mike Porter
Elkton, MD
