Hi, I have built a few ARF's but never foam core. I recently jumped in an built an FT Sea Duck which was a mistake as a first build. I had a few issues using the hot glue gun. I have the Pro200 like Josh uses but mine for some reason continually dribbles. I loose more glue than I use. I also use Flitetest glue sticks. I let a fellow RC Club member maiden my Sea Duck and it ended up acting like the thrust angle was off so every time you throttle up it climbs pretty steeply even with the CG perfect. Anyway I also found using the hotglue doesn't give you a while lot of time to place and align your pieces before the glue sets up. Still a lot to learn here. Glad to be on the forum. I am sure I will learn something.
