I'm relatively new to multirotors, having only a Traxxas QR4 before.
I went in feet first and bought the Batbone tricopter kit.
It's equipped as follows:
Turnigy Park300 motors
GemFan 8x45 props (CCW only)
Turnigy Plush 18A ESCs
Turnigy XGD-10HM Digital Micro Servo 2.2kg / 10g / 0.12
KK2.0
Here's a terrible picture of it:
I got it up an running the other day after taking my time to make sure everything was right.
- I've setup my KK2.0 trims so every is zeroed
- The channel move in the direction indicated on the KK2.0 (I assume when it says right/left/up/down that is the direction the TX stick is supposed to move)
- Calibrated the KK2.0 on a level surface
- Set the PI values to what was recommended on a tricopter video on YouTube
Now for the issues I'm having:
1. The tail servo assembly doesn't want to center. When my TX stick goes back to center the tail assembly wont get back to center automatically. I can move then stick a bit then release again and it seems to center. The servo I bought has equal or better specifications to the one recommended by Flitetest. Do I just need a higher quality servo or do I potentially need a stronger one? The tail assembly doesn't seem to be binding and the servo will move through the entire range of motion.
2. Once I get the tricopter into a hover it wants to yaw the the right slowly. It requires a constant left rudder input, about 25%, to keep the unit stable. I can't really tell if the yawing gets worse as throttle increases or not. Is this a KK2.0 calibration thing or do I need to be playing with the PI settings?
3. Motor temp on my tail motor seems high. After a few minutes of flight, I can touch the motor, but I can't leave my finger on it very long. It seems to be getting warmer than the two front motors. The ESCs for all motors seem about the same temp. I imagine that the tail motor has to work a little harder than the front. I don't have an IR temp gun, but supposed I had a way to measure the temp, what should I be looking at as a max temp?
I'm nervous about the motor temp as the first tail motor I had failed on the first flight. I got luck and was only about 5 feet off the ground over grass. The unit flipped backwards, but landed up right. When that motor failed, the body was so hot it burned me the instant I touched it. The failure mode had to do with the position of the motor leads. When in a certain position, the coil was shorting. That motor was a total loss.
I appreciate any guidance the more experienced folks here can provide.
KK2.0
