Hey all.
I've built a tricopter based on David's fine instructions, and finally received the props I've been waiting on.
The board is the HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA), the motors are DT750 Brushless Outrunner 750kv and the props are 10x4.5 SF Props. Radio is Orange R620 Spektrum w/matching receiver.
I had some trouble initially flashing the board, but managed to get it flashed to Tricopter v1.6 by kapteinkuk.
After balancing and confirming prop spin direction from the "Tricopter - Scratch build" video here, I took it out back for a test run-up. The props all started spinning when I brought in the throttle, but wasn't off the ground by half-throttle. I barely touched the right stick and the right-front motor immediately spun up to full speed and flipped the copter over, separating the left motor from the boom.
Can anyone give me some items to double-check before I try again? This is my first tricopter.
Thanks!
#mikec
Thanks!
#mikec
