Hi all, I'm a noobie that was inspired by David's tricopter 2.5 blog all that time ago. It's taken me until now (or rather until 2am last night) to finally build it. Everything went extremely smoothly and I was very pleased with myself
I've been setting up the TX and testing the motors (DT750) etc (still no props) and I've noticed that the tail motor does not start up with the front two. It starts at around 40-50% throttle
I've calibrated all the ESCs (Turnigy Plush 18a) by connecting them to the RX, throttle up/down etc and programmed them with the Turnigy programming card as described by David. TX trims are centred.
The controller I am using is the HK Multirotor Control Board v2.1, flashed with the Kaptain Kuk Tricopter 1.6 as the KK2.1 was out of stock, all pots are set to 50%. I've had a go at calibrating the board using the zero pot setting, but to be honest I am a bit confused as the documentation for this board is a bit sparse, or maybe I need some sleep
I've tried swapping ESCs and motors, the same happens. When I hold the tri aloft and move it about at 50%+ throttle, the motors spin up and down the way they should, inc tail motor and the yaw mech works a treat. Anyone have any clues?
