Northrop T38 Thunderbird version EDF - done
leaded50
looking pretty slick, did you just do the paint scheme in sharpie?
Fuselage is painted in white spray, windows used a blue paint and a swamp dragged over to tone down blue color, pluss give a foggy/ window effectJ. edges on window is markers, same as the rest, decals/blue stripe at freehand.(no weight anyway)
leaded50
carefull adjusting of skins to fit best possible. Sanding on every seams, then use of lightweight drywall filler to adjust where necessary, and sanding. Then auto sprayfiller, sanding again before paint.
Close up it can easier see some places where the seams are though.
leaded50
@CrazyFastFlying , i doubt he would liked this one, just of foam :LOL::ROFLMAO::LOL: Ha,ha.
I have had that 64mm upgraded 12 blade EDF laying here over a year, it about time its used.... and to make a nice jet now when understand how foamboard can be used, and shaped, fit right.
Its not totally scale, a touch higher profile, bigger intake profiles, and adjusted wing size to glide better eg. but im satisfyed with the outcome.
I plan using whole elevator wings adjustable, no rudder, but ailerons/flaperons that also could mix with elevator.
leaded50
The Jet is done (close too) At least in paint. Still in two parts, since waiting for some servos, retractable landing gear eg.
The upgraded 12 blade EDF with 2822-3500KV motor and thrust tube is in place, also the red-brick esc with the cooling ribs under the belly.
Many of the EDF planes is tailheavy, here i get the EDF closer to the CG (where the the two parts of fuselage is connected) who did fit perfect with 3 or 4s battery in cockpit. No need for extra weight to center the CG. Im using the 64mm EDF, but by adjusting of the inside formers at top, even 70mm EDF could be put inside.
It was ment to be a copy of the NASA Talon, but needed changes to fit my purpose. My plane have a "fatter" fuselage to get place for the EDF without making a longer/bigger plane. I didnt want it bigger, or possible heavier. This is 800g ready with battery (will be more with retractable landing gear) who will fit nicely with the 1250g thrust. The intakes to the "jetengine" is bigger than on the Talon, and both is correct to total of the EDF (no need for extra cheaterholes)
Main fuselage is by 8 sections, formed the "masterbuild way"
Length 950mm
Wingspan: 730mm
leaded50
Its more or less "buildt as go" but will try put together a buildplan of the jet. Most of the parts "skins" are stored.
And you know.. another shape of tailfin & cockpit, changed the wings/eleron. to delta style.. we got close too a french Mirage Jet...
