Scottie
So after my latest re-designed Piper Cherokee
http://flitetest.com/articles/piper-cherokee-build-log
and feeling I have found my build style now,I have decided too go back too my P51-B
http://flitetest.com/articles/p51-b-mustang-build
and re-design it using my new design process.
Now before I get too far ahead of myself here,a quick word on the Cherokee,just in case anyone asks.Yes I have ran taxi tests but not had a full maiden,weather hasn't been preferable thus far and when it has,I've not been able to try
...... annoying doesn't cover it !!
Anyway,I decided to do something which I generally don't do,this build is a prototype to test and tweek the build process,to make adjustments as I build and to figure out the skin process.All these adjustments are updated in Sketchup as I find and make them.
That being said,I don't normally publish any of this but this time I thought it may be interesting for some to see how I design and build my models.
SO the concept has tp come from somewhere and generally it's a 3 view or a good set of plans/drawings.In this case its a set of plans found on the good ol internet
From there its into Shetchup and several hours if not days later,I come up with this.........
I mentioned 'my build style' well to clarify what that is,basically my builds are aimed at a more scale appearance and for a more advanced builder.Think along the lines of a balsa build and you're getting the idea.I think the whole powerpod concept is a great idea but it causes so many problems from a design view.Obviously in a design there are requirements which need to be met,battery access and placement is the biggest one I think,so to overcome this,I decided a new approach was called for,certainly from the standard battery access of shall we say a traditional FB build.
The thing is,using foam board as a material,it doesn't stand up well to things sch as a removable hatch.
My solution ,which I first showed in my Piper Cherokee build is an adjustable battery box which is accessed from the wing seat.
Im not one to blow my own trumpet but I'm pretty pleased with this concept,it sets the basis of all my builds,all designs and concepts are built around this.So onto the good stuff,I think I have finally figured out the whole producing plans malarky !! I use Sketchup firstly then import into Gimp2 as a PNG,use Gimp2 to size the drawings then save and export as a PDF.seems to work....
The observant of you may notice I print formers and smaller parts onto an A4 print,it's so much easier to work with .
Anyway,thats a start......more to follow.
Scottie
Specifications
Wingspan
1120mm
Length
960mm
Weight
TBA but definately heavy !
Wingspan
1120mm
Length
960mm
Weight
Scottie
