raptor3dpilot
So I have two Depron/MPF (Model Plane Foam) aircraft that are just about ready for paint. Looking for some suggestions on how not to screw them up.
HAHA. I've spent a lot of time building them straight, prep sanding every inch, and now it's time to paint.
First question, as of now, these are just airframes (RCP F-22v2, RCP F-18v3) with no electronics. Should I paint before the electronics install or just install the electronics and then cover them with tape prior to painting? I worry about hot gluing the servos down directly to paint and having them come off due to the paint peeling from the foam. Maybe I should just cover the servo locations with a square piece of tape, paint, then install... hmm.
I don't have access to an airbrush system nor the funds to buy one, so I was planning on just using Testors rattlecan paint to paint them. I'm thinking a light coat first and then finish it off with a heavier coat after it dries. Is that the correct process?
Decals are next, I'm sticking with the standard AF markings for the F-22 and Blue Angels theme for the F-18. Anyone have suggestions on decal paper that works well with an inkjet printer?
I've built and flown several F-22s, F-117, FT Spitfires, and other aircraft, so that is the reason I am spending a lot of building time on making these "pretty". lol
