Parachute for quadcopter: video showing it working
tecdux
Hi folks, how are you? Since I had some problems with quadcopter (propeller broken or not tied enough ....) I created a parachute for my quadcopter, so in case of a failure, I can press a button in my transmitter that will release the parachute.
I'm thinking in using it also with failsafe, in that way, the paracchute will open if I lose signal.
Here's my first test:
http://www.youtube.com/watch?v=dwY1h0khO_s&hd=1
I've tried a new positioning for the parachute, this time it's located on the frame
I have tested in my "wind tunnel" (hheheh) and it seems that's going to work in field
http://www.youtube.com/watch?v=iBBm3TQe49U&hd=1
New test!
This time the parachute is on the hquad
I've done a slow motion of the parachute opening and I've also put an onboard camera
Check it out:
http://www.youtube.com/watch?v=2cBSVpUSCEc&hd=1
More tests to come! ;)
tecdux
#3
There's this problem of the minimum height but it can be reduced used some mechanism to launch the parachute (CO2, spring ... for example) ;)
