I thought I was ready to print then realized you had wing cutouts and I didn’t.
Main thing I’m not sure about is the wing cut out on the fuse. How did you come up with the measurements?
Also I don’t know how you came up with the cardboard pieces at all.
I noticed you put the holes in for the power pod to mount into the top of the
fuse. That is easy to figure out, just almost didn't catch that.
Just noticed you had done a few things to your project between 5 & 6 but did not
show how you did it. Want to make sure I'm not missing anything.
I'm adding a link to the project picture I'm working on that I have followed you by. Its not the same plane
as yours its a F4U Corsair. But using the same guidelines as yours. If you look at the wing, you will see why
I'm having issues coming up with the correct measurements on the cut out for the wing.
If you need or want, I can send you my PSD file with what I have so far.. Its almost done.
Thanks for making these tutorials! THEY ARE AWESOME!!!
http://www.poweredmodelairplanes.com/pma/george/corsair/corsair01.html
