It ended up being half a maiden as I had the prop direction reversed (note to self) and therefore only did some hand tosses - plenty of potential though!
Hi guys - I have had a couple of requests for the STL files for this project - no problem!
The glider started out as a DLG and ended up being a propped V tail so I will probably need to make two sets of files - the wings and tails should be hot wire cut foam and then vacuum bagged with fibreglass.
Hey, I read through your forum posts with great interest and I'm now hooked on the idea of building a glider with 3D-printed molds myself. I'm specifically interested in the DLG variant. If you're still open to sharing the files, I would really appreciate it!
I would be happy with STLs for the moulded and vacuum bagged version. I would probably build both dlg and electric version. I also wouldn't mind paying for them.
