Ranger_107
hehehe. My dad ordered an esc for a 70mm edf 2 months ago and we are still waitingme too!"!! The ESC is here at monday latest, and then ill try do last checkups, even if not got all retracts till then.
Ive ordered a few last 6 mnthsfrom Asia.. and must say, they are shipped (the ones who have come) by bicycle or somehinghehehe. My dad ordered an esc for a 70mm edf 2 months ago and we are still waiting
Your in Norway too? and what size ESC do you need?Looks amazing!
Got any recommendations on where to order ESCs? (I assume you are in northern Europe just like me due to the "Biltema" piece in the "wingbox"). They either seem to be very expensive or delivered slowly.
I'm in Sweden. I was looking at building a FT Viggen. With a FMS 70 mm EDF I would need a 70 A ESC. The price difference between HobbyKing and rcflight.se was 48€ (19€ vs 699 SEK). The shipping time also differs a lot. I suspect the quality differs as well. The question is if I need the quality of the HobbyWing ESC (and if the quality difference warrant the price)?
I then saw Tom Stanton's video with a 70% FT Viggen. That can use a 50 mm EDF and then the prices gets to a more manageable level. After all I really want the "local" stores (i.e. next day delivery and Swedish consumer laws) to survive and I'm happy to pay a premium for that.
I read about it @jfaleo1 Also that later model (Altaire ) they did made automatic adjustment system to counteract it. Im not sure, but tryed to think about it, when i setup the wing incident, and edf thrust angle. Motor is placed higher than the fuselage, so such motion is "normal" Thats also reason thrustangle isnt always 90 degree on with a prop plane with high mount either, special if pusher or on front of tailfin.
I did make a EDF test today, with connect it to another plane just to see how function, and its rare see a minor "twist-reaction" on the tailfin on a plane by full speed up. Its buildt sturdy enough, so not afraid it breaks eg... just a rare minor motion
I am very glad you saw all of this already since I came to this so late. Just for fun.....You are very right about incidence on propeller aircraft but, jets do it too. On the airplane I teach maintenance on one of the changes that was done between the Citation X and the X+ was the angle of the engines relative to centerline in both the vertical and horizontal planes. This was due to changes in the amount of thrust and the length of the airplane. Done with fun and useless knowledge transfer now.
699 SEK was high.... i byed mine 80A for approx 380 SEK. (but thats not normal pricetag) mainly i like the Red Bricks buyed eg from Ebay. Just rememeber some (opto??) is some version without BEC, some with.
In my opninon, a 50mm EDF is not perfect for even a 70% Viggen, they mostly have a thrust of 650 - 750g max. theoretically, and also thrust on a EDF isnt as on a propeller at the startmoment. When plane got up in speed yes, ok. Started by a "slingshot" is nice! At a prop plane they say it can be approx 30-40% less thrust in g than the plane is weighting... at EDF it need easy be 30-40% lighter than the thrust of the EDF, if not a wide wingspan glider.
should have been. Still awaiting for a few cables in mail, so can complete its functions.Is there a maiden video?
ITS HERE!!!hehehe. My dad ordered an esc for a 70mm edf 2 months ago and we are still waiting
Quite normal you need solder on batteryplug and female bullet plugs.
huh? max out? the motor needs at least a 45 amp but 60 is all we could get.Quite normal you need solder on batteryplug and female bullet plugs.
Be sure your EDF dont max out over 55-60A.
if the EDF draw more than 60A max, yes, you will get a "smoke-out" esc get to hot, and destroy it self. To big ESC dont matter.huh? max out? the motor needs at least a 45 amp but 60 is all we could get.
will the edf break if we have too big of an esc?
60a will be fine if your EDF only pulls 45a max. It's good to have some extra head room. You probably could even run a motor on it that pulled 55 or 60 and you'd be fine.huh? max out? the motor needs at least a 45 amp but 60 is all we could get.
