Plans Help
Craftydan
Hostage Taker of Quads
Can any one help with converting a JPEG picture into a PDF that can be printed out to build?
Simplest way for the "format" -> PDF is a PDF printer driver. I've had good success with CutePDF, but there are many others.
Good luck with the layout. look forward to seeing the build!
#3
How do you want to build it?
Simple prop in slot profiles
Or fully shaped fuselage with twin deducted fans
Are you building out of foam? Or balsa or what? I would like to help but more info is necessary
