Power Pod Motor Compatibility
mastermalpass
Is that the Hobbyzone Carbon Cub? A quick google I've done says that's a 960kv motor, you can swing a pretty big prop with that (10 inch, maybe 11inch slowfly) - stick that on your power pod and you've got a power system to serve an FT Spitfire Swappable. :D
Raxaphone
But will that motor fit in the firewall for the power pod?
mastermalpass
If the motor came with it's little Metal X mount then hopefully, as it's a similar level as an FT standard, it should fit right on. Otherwise, you might be able to make the firewall fit the motor by drilling some holes - hopefully the holes that are already on the Firewall don't make it so you would be drilling new holes too close to them.
Otherwise, it won't be hard to cut a new Firewall for yourself from some 2mm or 3mm plywood - which is what I've always done, though it can sometimes take a couple of attempts to get the holes in the right places.
