Product Questions
Av8Chuck
Hi, my first post. I'm hoping the folks at Flight test read this forum.
On their recent video they showed a detachable landing gear for multirotors but I didn't see it in the shop, is this available?
Also, I've never built or flown a tri-motor, looks great and I'm interested in learning more. I fly with a PixHawk, will that work with a Tri and how do you set it up?
I would also like to fly an AUW of about 15+ pounds using these motors with 15 props":
http://www.kdedirect.com/collections/xf-multi-rotor-brushless-motors/products/kde4215xf-465
Traditionally for these size motors I've been using 25mm CF tubing to accommodate larger motor mounts on a Y6. If I went with three, instead of six motors I'd have to go with slightly larger motors and 18" props. Would the "Tough Tilt Motor Mount" handle that? Any chance of making one that fits 25mm CF tubing?
Not sure if a Tri is the way to go with this much weight but I sure like how it flies and it looked like it was fund to fly. This is for a 3-axis gimbal and GH4.
Bellke
Not sure why you're saying you can't fine the detachable landing gear, look under multirotor
The landing gear is not available yet. It sounds as if that's a new product they're still working the kinks out of and making sure the results are reproducible and solid. God knows I wouldn't want to ship something that isn't as stable or reliable as it could be, doubly so given people could be mounting fairly expensive gimbals and cameras on it.
I'm very interested because I'll probably build a couple different lower ends for different uses depending on what I'm doing. Definitely got my attention.
CrashRecovery
I'm a care bear...Really?
The landing gear/camera mount/battery holder you saw is almost ready to hit production. Eric has a few things he is cleaning up and then you will see it. If I understand eric right you will not be waiting long
Cad
First post here too and am looking to build tricopter. I was curious as to how much the wood booms weigh as opposed to aluminum c channel or square tubing.
CrashRecovery
its not the weight of the aluminum tubes its the strength where you bolt things to it. with out having something in there to brace it could collapse
earthsciteach
The aluminum box tubing is very light and is quite strong. These work great for larger multis. The oak booms are heavier per length, but the extra weight is no issue for a small multi like the Electrohub. Pretty insignificant, in fact. Both are very inexpensive and easily replaced.
Cad
I was thinking about saving weight anywhere possible. As for the tubing, having wood inside at attachment points for strength. On Eric's tri he has the booms angled I take it for added stability?
