Long time no update on the Tomcat, I picked up the project again and finished the 3d model, there was quite a bit to do on the internal structure. I also finished the first version of the plans. It is 8 sheets foam, but its the European sized foam (70x50 cm) so they are a bit smaller than us foam, so I might be able to fit it on 7 20" x 30" sheets.
I also got a pile of foam that is lighter than the foam I used on the mirage but still quite a bit heavier than the ft board, but Im going to build one now. Im going to remove as much of the paper as possible on the inside of the pieces to save some weight. The electronics I will use are 2 fms 61 mm edf, 2 9g servos for the all moving elevons, 2 23g metal gear servos for the sweep and 2 40A esc, yes 40A is barely enough but I will place them in the airflow inside the engine, they should be fine. But before all that I got to cut all that foam by hand
