I recently did a drive efficiency analysis on the table for the 2805.6 1800 KV motor with 9x5 x 3 blade prop,
and it worked out that rpm was about 8,000, thrust was 78 % of expected, motor was 77% efficient, extra thrust due to blade friction was about 75 % effective,
and total drive efficiency over ideal was 55 %
I calculated friction at 0.01 Ca, 2 blades, but actual test prop was a 3 blade.
The motor used less amps and made more thrust on an 8 inch prop of unknown specs.
Computed flow velocity was 21 m/s (about 40 mph).
There doesn't seem to be much room to improve thrust efficiency by adding blades.
was 0.01 Ca a good measure of drag? - a propeller has relatively low profile drag, and higher surface drag.
Is my proportioning of loads and rpm estimate any good? how would errors affect the calculation results?
