PT-17 Stearman
PT-17 Stearman 1.0
Please log in to download
SP0NZ
FT CAD Gremlin
Admin
SP0NZ submitted a new resource:
PT-17 Stearman - PT-17 Stearman Free Plans, Designed by Ben Harber
PT-17 Stearman
Design by:
Ben Harber
Plans by: Dan Sponholz
Ben Harber designed this amazing 1 : 9.65 scale Boeing PT-17 Stearman built from ADMAS Readi-Board (a.k.a. Dollar Tree Foam Board).
History:
The Stearman (Boeing) Model 75 is a biplane formerly used as a military trainer aircraft, of which at least 10,626 were built in the United States during the 1930s and 1940s. Widely known as the Stearman...
Read more about this resource...
SP0NZ
FT CAD Gremlin
Admin
I see in the listing that this should include the vector files for this build. I find the PDF download includes bitmap images only. How do I get the vector format for this file?
- Type: Build Plan (PDF, AI, etc.)​
Where does it say anything about vector files?
Rico
Fair. I am new to this resource and assumed a file in AI format would be included, which would have the vector paths defined. I was looking to cut these components using a laser vrs my old hands and a knife. :) Are vector files available?
Hi it is not possible to use these planes in LightBurn to cut them with the laser, you can have vector planes. Thanks and congratulations
SP0NZ
FT CAD Gremlin
Admin
It's not an AI file, it's a PDF. The PDF is in raster format, as you have already discovered. A vector file will not be provided at this time.
Mr.Talldad
Another amazing plane! Looking forward to this build. I use Inkscape to create Gcode for a needle cutter to cut out the planes. I have used this method on several PDFs from Ben/Sponz. However with this PDF file I am unable to ungroup them fully to to move and remove objects, delete lines, etc.. Any help will be great. Again thanks for all you do.
Addicted
The raster format pdf serves its purpose.
If you want to use a cnc to cut the parts, you'll need to start by tracing each part line by line.
bobmorey
Hi sorry for the dumb question - if we want to print out the PDF full size, what size sheet is this? I see some are small A, but the larger are D or E size (old drafting sheet size terminology) I assume? Thanks!
CrshNBrn
I'd love to see some comparisons between the Ben Harber & Johnny Gum versions. I built the Johnny Gum design a few years ago and it is still looking good although it's always been a little tricky to fly. I wonder how this one will compare?
The PT-17 is a gorgeous airplane, and we are all lucky these folks are willing to share their plans with us. Much obliged!
wilmracer
I build things that fly (sometimes)
I can't speak to flying the Johnny Gum version (never heard of it actually) but Ben's design flies beautifully. VERY scale if you want it to be. Once I had the thrust angle right for my setup landings were a non-event and it did whatever I asked it to.
