These started as an exercise in SketchUp. I built Puffer and the foam proofed out well. The plans were a success. Today I put electronics in Puffer and it flew great. This is a standard tail volume and tail moment that I use for my smaller scratch built acrobatic planes. The wing is a standard three break wing that is based off the FT Simple Soarer wing geometry. The difference between Puffer and Guppy is a 90 degree fuselage rotation. I have not tried Guppy yet.
Sorry there is no flight video. Just not possible rite now.
8x6 prop, 24gram Hextronic 1300kv motor, 10 amp HK ESC, 3S 1000mah battery, and four 9gram servo's.
Peel the paper off the inside of the fuselage, it helps achieve the curves. All the tape you see in the picture is not required. That was just used as part of my proofing process. Plus I like to skin the belly because I belly land in rough terrain.
Just mark the wing slots, don't cut them till the fuse is assembled. Use the constructed wing to proof the marked wing slots before cutting them out.
Fabricate a firewall (I used a water bottle lid).
Cut an access hatch in the nose from about 1" behind the firewall to the first wing break.
The wing is 30" long and has 5" of under camber at each end (under camber is optional and roll rate will increase without it). If you don't want to print the wing plans. the measures are simple enough. 5" from edge of foam (trailing edge) to second break (score cut). 1 1/2" from second break to first break Score cut). 1 1/2" from first break to Leading Edge (double bevel). 6" to end of bottom plate. Size ailerons as desired (at least 8" - 10" from wing tip toward center and end of bottom late to trailing edge). The spar is two pieces thick of foam 18" x 1", centered between the 1st and 2nd break, side to side. This will leave one inch open at each end to sandwich the aileron servo's between the top and bottom plate.
Here are the plans. Once they are open in PDF, use the snapshot tool to frame in as tight as possible the fuse and stabilizers you want to build. Print that snapshot as POSTER at 100% and it should fit on six sheets of paper. Do the wing the same way and it also fits on six sheets of paper.
