PsyBorg
Wake up! Time to fly!
Started prototyping the variable pitch hub for the big boy
In your final design make sure you are using thru hole bolts or roll pins to hold the blade grip shafts on both ends. Set screws will NOT be enough to secure them under rotation with the mass of the blades. They will self destruct with a quickness at some point should one ever loosen.
