Raptor 30 Tail Wag
FlyHi75
I just bought and setup a raptor 30 v2 and it flies great. When I brought it into a hover there was a little tail wag so I lowered the gain. There is still a very slight oscillation. Is there always going to be a little because it is gas? When I give a rapid rudder input sometimes the tail begins to wag aggressively back and forth. It is strange that it only does it sometimes, any ideas? Thanks!
#2
Sounds like the gain is still too high. It should lock and hold the same for a gas or electric heli.
What gyro are you running? Digital tail servo or standard? What are all your settings (delay, travel, etc) on the gyro itself? How/where did you mount it?
Typical setup for a gyro is to start at a low gain and work it up slowly until the tail begins to wag, then back it off to the highest gain setting that doesn't wag.
FlyHi75
#3
I am running a Ace Rc TG7000 Gyro, with a Ace Rc DS 0606 digital servo. I don't know the gyro settings; I don't know how to tell what they are on the gyro itself. The gyro is mounted behind the swashplate flat and right side up with plenty of gyro tape.
