RC Ornithopter
Hello all, I was assigned a project earlier today concerning Leonardo da Vinci's Flying Machine. We basically have to build a flying machine according to Da Vinci's sketch and explain boring stuff like why it was invented. Meanwhile I decided to not just make one, but make it fly. To do this, I've spent a few hours on YouTube looking at other people's ornithopters and I've got an idea of what mine will be like. According to this video:https://www.youtube.com/watch?v=e3wWfKEdvpY It will use a crankshaft and connecting rods to move the wings. Unlike the video however, it will use a motor instead of a rubber band. The motor will not have a speed controller, I don't have a brushed ESC and I don't have a small enough brushless motor for the weight to be low enough. In addition, there will be a kill switch on the bottom so the motor doesn't keep running after landing. I will be using, plastic bags or whatever lightweight material to be the wings. In addition, the wings will be angled, a bit like a seagull (or an inverted Corsair) somewhere for better lift up than down. I also hope to make the wings cambered for efficiency. The dimensions are: Wingspan: 42" Length, 30". For control I have a 9V battery going to a UBEC with two outputs; one will be for the receiver/servos, and the other for the motor/potentiometer/kill switch. One problem is, how do I propel it? I could easily put a propeller on the crankshaft, but I'd rather manipulate the wings in some way especially since the motor will be doing low RPM. Also, the Servos are a little troublesome with the arrangement, the tail is like in this video https://www.youtube.com/watch?v=9W4OisoX2xo
As usual, suggest, and comment as you wish.
