Retro Rocket EDF Thrust Vectoring for 70mm
Retro Rocket EDF Thrust Vectoring for 70mm 2.5
Please log in to download
Mr.Grinch
I finally have useable examples, the PETG has a bit much stiction, but will probably work. The ABS did split as well, but only the lowest part, which may have just needed more heat, but its still a usable piece.
Thanks!!
Mr.Grinch
Made another set in ABS last night, it still split, but I carefully acetone welded it back together while making sure the nozzle didn't fuse to the base. It looks to be the best result of all the attempts so far.
johnbecker31
Looking forward to hearing how the maiden went! Keep on flying!
sfarr015
I created it in fusion360. I will have to see what I can do to make it available.
You should be able to save a file as a STEP file in Fusion 360 by:
  1. Select File
  2. Click Export
  3. In the Type drop-down menu, select STEP Files
  4. Name your file
  5. Choose the location to save your file
  6. Click Export
