Okie
Flite Test Aviatrix
Scale Build-Off – 42" P-47
Electronics:
Setup:
Turnigy D3530/14 1100KV Brushless Outrunner Motor
45Amp ESC
APC Style Propeller 9x6
Slow Fly Electric Prop 9047 SF
Slow Fly Electric Prop 1045SF
2200Mah 3S Nano Tech Battery
Orange rx /turnigy 9xr
4 9g Servo’s
Y Servo Lead 30CM Length (5pcs/bag
30CM Servo Lead Extention (5pcs/bag)
Building material:
5 sheets (maybe less )
2sheets poster board
DAP. lightweight spackling
Loctite spray adhesive
hot glue
describing the work
as you can see the fuselage frame is a box and rib construction then skinned in poster board I used lightweight spackle to fill the gaps in the over lapping skin. the motor cailling is laminated DTFB with posterboard on the outside
UPDATE 02/12/1015
the painted plane
UPDATE 02/02/20015 The wing construction is the basic flitetest method the wing spar is tapered from 1/2in to 1/4 in the servo are tucked back in the wing and it is a razor back version I haven't decided on a paint yet
so this is my second entry in the scale build off I always wanted a P47 so I started on this little jug wind span is 42"in and is a little over 30"in long the designe is my own the construction is a box fuse with rib on the out side then it is going to be skinned in poster board I will be using a power pod but I think it will be glued in and will not be swappable here is the progress of my work
UPDATE: I've got all the templates for the skin made and started to put on the poster board on an also waiting for the parts to get here
more pic
Electronics:
Setup:
45Amp ESC
4 9g Servo’s
Building material:
hot glue
describing the work
UPDATE 02/12/1015
the painted plane
more pic
