Scaled FT plans - available by request
MikeBg
Will the Simple Storch fly at a 75% or 50% decrease in the actual size plans printed out and built? I want to build this plane but it's way to big for where this old handicap man fly's! Thanks 73 Jimmy, ARRL TS, WX9DX
I built Stroch at 75% with no changes to the plans...
The fuselage is too narrow for a standard power pod so I made a hatch to access the electronics.
Here is another build at 75% but with the fuselage widened to fit a standard power pod.
It fly's well if you get everything right, I had to tilt the motor down and right to keep it flying level.
MikeBg
Jan Chakk
Scaling Mini scout for 6mm foam
Hi
I am new to this forum, so let me say Hello ! to all you guys who have contributed tons of very useful information.
I have read through most of the posts in this thread and am interested in building a FT Mini Scout with 6mm foam board. I think the plans (available at FT) are more suitable for 3mm boards and from the build video it appears like that..
My question is by how much should I scale up (0r should I?) the plan to use 6mm foam?
Regards
JanChakk
evan
Hi all, I wanted to share a YouTube tutorial that I just put up on how you can rearrange and reformat and even modify and scale Flite Test plans using the free graphics editor Inkscape. It's a pretty long video, but it explains the problems I had with printing plans the standard way, goes through examples of how I improved the process for myself, and then goes step by step through rearranging the FT Mini Scout plans. I end by talking about how you can use Inkscape to scale plans as well. I hope it's helpful, I'm in the process of putting together an article for it as well. I recommend watching the video over on YouTube itself, in at least 720p, and as full screen as possible, as I didn't anticipate how faint the lines for the plans would appear.
nerdnic
nerdnic.com
Hi
Regards
JanChakk
DTFB is 4.7-5mm so you'd need to scale about 15%.
Frido
You're very right Nerdnic.
A and B fold do not fit also.
But I build in polypron. Anyone building in polypron or depron can't use A and B folds cause it got no paper on it. But if they're a bit inventive they will manage as I do.
I build a 50 percent spitfire out of 3 mm polypron yesterday, think I'll make it a glider without motor
Scaling this way could take some of the pressure from you :)
Hi Marc,
I see what you're trying to do. I will try to build a 63 % Storch, since the foamboard thats available in the
Netherlands is 3 mm and 5 mm, at petervanginkel.nl this has paper on it...
So the FT / Dollar tree foam is 3/16 ", this is 4,762 in millimeters, so if I convert a Storch to 3 mm foamboard
it's 63 % and to 5 mm foamboard it's 104 %
The A and B folds should fit or am I wrong ? I'm a total newbe by the way.......
The Spitfire looks great by the way !
Greetz
bhursey
The Geeky Pilot
Has any one been able to scale plans to fit the mini pod? I am thinking it is either 60% or 70%... 80% is to big just checked on a print.
ruud
A 60% scaled-down plan will fit the Mighty Mini power pod exactly. That's how I built my Mini FT Spitfire.
bhursey
The Geeky Pilot
Do you have the mini spitfire plan? That is one that is on my list. It would be awesome to be able to build it. I recoverd some 9g servos from an old airplane, and I have a 5 gram I believe also.. I could have the 5 grab do the ailerons. Basicly we just had to replace our ac unit.. 6k.. so I have 0 cash to build anything.. I can justify 2$ is foam but can't justify 60$ in electronics. :) How does it fly?
FeWolf
FT Bloody Wonder 80%
FT Simple Soarer 80%
I build alot of planes for the kids on my street and would like to cut down of cost to myself alittle, the Bloody Wonder is for me :)
ruud
Do you have the mini spitfire plan? ... How does it fly?
Sorry, I just printed the normal FT Spitfire plan scaled at 60% and manually adjusted the cuts for slots, tabs, etc. Requires a bit of "3d thinking" to figure out what goes where and which way you need to move the cut. I decided to leave the rudder fixed.
It flies just fine. I forgot to build right thrust into mine so it has a bit of a torque roll issue on launch (especially on 3s) but otherwise it is a great plane and handles just like its big brother although it flies relatively faster.
bhursey
The Geeky Pilot
It take just like 3 boards? Fixed ridder will actually be good for me because of the number of servos I have available.
Any special reason why you left the rudder fixed? Just wondering. I might give it a shot
ruud
I didn't feel the need for it, there wasn't much room, and was worried the extra weight of the servo might make the plane too tail heavy.
