BobK
Banned
Wow, she looks awesome, Bob. You did good with the vinyl trim. Not too much because you want to see the cutout work through the covering. It will look cool with the sun shining through the wings. You get sun in MN right?
Haha yes we do, even breaking record high temps today in the mid 40's. Still windy now but it is supposed to drop later on. I still haven't decided if I like the colors but Thanks for the compliments, I've done better lol. Worst part about attempting something new like with the gift wrap covering is to me it looks horrible knowing it should look better, 30 years of covering airplanes and I feel like I am just learning..guess I am.
Please take a photo of the bottom. I'd like the see the details on the landing gear and bottom hatch. I'm always looking for a better way to make landing gear since that part of the airplane takes the most constant abuse. Landing gear is a must here in the desert where large grassy areas are uncommon. I get maiden flight jitters too as evidenced by the Schoolgirl maiden flight video. The first few flights of the early version Ranger did not go well and are still fresh in my mind. Glad I got that design worked out. I'm going to fly the Ranger today with a new, improved fuselage and landing gear design.
With the size I am able to use prefab aluminum LG, this could be made from flat 1/8" aluminum stock on your own, I think thinner aluminum stock could be used on your plane even if it is a bit heavier than what you have, looks like yours could carry some extra weight no problem the way it flies. The LG gear mount is wood and goes from the back of the bottom hatch to the bottom wing TE, I have been buying yard sale sign stakes at Walmart, very inexpensive and nice clean light wood.
When I built the fuse I cut the doublers 3/16" smaller where the landing gear mount and hatch doors go, this creates a shelf for those items to sit against, then I cut the actual hatch doors just a bit large to fit tightly for a friction fit, over time I might have to hinge them but they fit nice for now. The top door isn't attached just flipped up for the pic.
The bottom wing of the Schoolgirl is right where you would want to hold the airplane for a hand launch. It makes hand launching awkward so I've been using my least favorite method of take-off, rise off ground. With all that wing she takes to the air quick.
I don't plan to hand launch, only problem I have is trees on one side and powerlines on the other..or to take off under powerlines so until I know the plane isn't going to bank one way or the other the maiden flight is always a bit of a cold sweat lol.
Your Ranger is a sweet plane, I might have to build that also. I have an old Goldberg Skylane 62 here that I was going to rebuild but it really is a mess..I salvaged it out of a load of garbage. It was built horribly and covered in fabric, probably in the mid 70's so as a rebuilding project it would be a lot of work..maybe a foamboard candidate?
