You have it right need the BEC or a separate BEC to keep the voltage down to less then 6 volts. Unless you have high voltage servos then it is 8 volts or less.
Don`t need the ESC IF you have a battery pack that has the plug on the end that goes into a receiver. I have many of those around as I fly IC engines either 4 volt or 6 volt pack.
