Hello all, I'm new to building model aircraft and especially foam. I have some sheets of Depron foam, which doesn't have paper on either side. Is there some secret method to fold back a wing top from the wing underside without cracking the foam? Also, has anyone tried covering the foam in Solarfilm type stuff or does the heat from the iron make that unwise?
Does anyone use car wrap vinyl? Failing that, what about paint? I want to use foam to make scale light aircraft, so nice liveries are a must.
Cheers,
Martin
Cheers,
Martin
