Simple bevel maker for ailerons
Coachbear52
I'm looking for a diagram for making a leveling tool for ailerons, been looking almost every where.if you have any suggestions they will be highly appreciated.
Bricks
I made my own using a piece of wood cut a 45 degree angle and super glue a razor blade to it, if needed I use a block of wood with 220 sand paper to straighten the edge. It takes longer but you can sand to the bevel edge using the block, be sure to tape the back side first.
...if you have any suggestions they will be highly appreciated.
I make my bevels by hand. I don't try to make them perfect, just close enough. Then I use a sanding block to make them perfect.
A very sharp knife does most of the work, a couple of sanding strokes is enough to finish the job.
My sanding block nothing fancy. Just a scrap of straight flat wood, with some sand paper glued to it. I have several different sizes for various jobs.
