JasonEricAnderson's Shetchup tutorials really got a ball rolling. I have started using Sketchup more as a proof of concept for scratch designing rather than modeling my favorite planes. I can get my dimensions and test fits before I start carving up the foam (I would rather kill electrons than foam).
I have been using Sketchup 2014 without flattery (there's something about doing things the hard way). Once I have a plan ready to print, I have been printing directly from Sketchup. Works fine. No cut marks or anything. Just lines on a paper that are accurate in dimensions.
Since not everyone uses Sketchup, I wanted to create PDF's so that I could share plans. Using CutePDF, I had some success. Nothing between, just Sketchup to PDF to print. When I printed the first PDF, my plans seemed smaller than they should have been. Hit them with a ruler and low and behold, they had shrunk. The scale guide in my plans was accurate so I was at a loss.
The issue came from joining the sheets. Printing from sketchup creates an overlap. I use the models lines to line up sheets by joining lines end to end under the overlap. When printing from PDF there was no overlap but there was a small margin.
The "Happy Accident": The plans lined up perfectly just putting the sheets side to side and top to bottom. Made alignment and joining so much easier. Perfect scale. The first test build from the PDF plans was a success.
Anyone else have a similar experience? Or, have a different technique (other than the one outlined by JEA)?
Be safe and have fun,
Tommy
Tommy
